Compression fittings.
11 Jul 2015
Glasgow
Just back from a job, leak on a compression fitting; some tw.t had used PTFE instead of Boss White on the olive??!!!
I remember when I started as an apprentice we got to a job and the boss white tin had got lost on the way (fallen off the back of a bike!:p) so the fitter used flux to make the threaded joints on a gas supply!:eek: I often wonder how well it held up:confused:
Is this a joke thread? Why should we put Boss White (or PTFE) on an olive? Doesn't the olive create the seal?
Nobody uses Boss White any more Puller, it's not WRAS approved :p
One that uses decent copper olives and doesn't overtighten everything.
Will get a leak, as it's a metal to metal joint & needs joint paste.
A little mechanical movement will also result in a leak - copper or brass olive.
I disagree but this argument has been done to death, and you're ***********
Yorkshire kuterlite say use a light oil on the threads and ptfe sealant if necessary with R250 tube and recommends using ptfe sealants with steel and stainless tube with tape as an alternative.
I use Jet lube V2 plus which is WRAS approved for potable/non potable , is a soft setting, non-petroleum based thread sealant for use on metal, plastic (non-ABS), threaded connections for water, bottled and mains gas, compressed air, oils, fuels, refrigerants and most other liquid and gaseous chemicals.
Remember , Hemp still allowed for gas . But only on that one fitting ;)
