Am I missing something here?
This is just regular twin and earth cable in oval conduit in plaster? With no particular attention to new wiring being pulled through in the future?
To my mind there's no point in using conduit if you can't pull the wire through. You might just as well clip the wire to the wall and plaster over if you don't want to do it properly.
Cobblers.
The main point of oval conduit or capping is to prevent the cable getting damaged from plastering up the chases.
If cable should get damaged in the future, it is certainly very beneficial if conduit has been used as it may be possible to draw a new cable in. Obviously there would be damage where a 90 degree bend is, and sometimes where the conduit meets the box.
Unless the op is determined to have his conduits done in such a way a rewire can be carried out without a damage to the walls, then I think it is reasonable, if not the norm, to simply mitre the oval conduits.
Round conduit which seems to be a minimum of 20 mm nowadays is the best option for a re-wirable conduit system, but depending on the number of cables required, singles may well be required. And if singles are required more round conduit may well be required to run the singles back to a convenient position.
I would say twin and earth cable in mitred oval conduit is absolutely acceptable in a domestic dwelling, with attention to safe zones.
