Fair enough - but I would find that way of looking at things pretty confusing - as far as I am concerned, the 'frame of reference' should be 'the circuit' (one end of the circuit if you like), whether the conductor physically goes in a straight line, round corners, round in circles, or whatever.I think it's something we could argue about all night. If I weren't too tired. But I stand behind the idea that if a a.c. current flows in the opposite direction to another, it is equivalent to a 180 deg phase shift. It's all a matter of frame of reference. But let's not go there.
I'm pleased to hear that. I personally don't see any point or need to be anything other than decent (even when dealing with 'stupidity'Yes, I will. Thank-you for being decent about my stupidly John. I will take all your comments on board.
I'm pleased to hear that. I personally don't see any point or need to be anything other than decent (even when dealing with 'stupidity'Yes, I will. Thank-you for being decent about my stupidly John. I will take all your comments on board.) - and I have a sneaky suspicion that, as a result, people probably often take more notice of me than of other people who take a more 'outspoken' approach!
Kind Regards, John
Has anyone pointed out that until the blue wire was connected it was not a neutral; it was a line conductor?Does the above quote not explain why the neutral wire was live?If you connect the Live of the machine to the Live in the wall and the Live in the wall is switched ON then the Neutral from the machine will be live as it is connected to Live via the electrical items in the machine.
I fear that statement has the potential to cause serious confusion in a DIY forum! In any event ...Has anyone pointed out that until the blue wire was connected it was not a neutral; it was a line conductor?
Whether it's a complicated machine or the filament of a lamp, these arguments that 'the blue wire' is a 'line/live conductor' until it is connected to supply neutral rely on the fact that the functional switch (of complicated machine or lamp) in 'on' at the time - and I suspect that even those foolish enough to work on a live circuit probably don't leave a complicated machine switched 'on' whilst they are connecting power to it!It may be easier to envisage if you substitute an incandescent lamp (just a wire) instead of a complicated machine as in this case.
It was your choice of words which I felt many would find confusing. If you has said that, under certain circumstances, a 'blue wire' coming from an appliance (or lamp), and not connected to anything, could 'become live' (or similar wording), that would be fine - but I still believe that to say that it was 'a line conductor' has the potential to seriously confuse.I must say I am surprised by your comments, John. ... Causing confusion may lead to those who don't understand to think about it a bit more - DIY forum or not.
In the context of this thread, (a) no-one has received a shock and, in particular, (b) the OP has just confirmed that the appliance was turned off at the time. Hence those 'certain circumstances' would not be satisfied and there is no 'simple' éxplanation as to why that blue wire should be 'live'. In the context of this thread (and assuming that the appliance really was 'totally off') I can but presume that we must, again, be talking about 'leakage', through stray capacitance or whatever - not the equivalent of continuity through a lamp filament.Imagining a filament lamp will make much clearer the reason why a shock was received.
It was actually in a relative's new house that I was working in.
Many appliances have the mains filter before the appliance;s ON-OFF switch and therefore the L-E, N-E and L-N capacitors in the filter are in circuit at all times including when the appliance is turned OFF.(assuming that the appliance really was 'totally off') I can but presume that we must, again, be talking about 'leakage', through stray capacitance or whatever - not the equivalent of continuity through a lamp filament.
I've no idea what you all mean, but the appliance was not switched on.
Yes, that is a definite possibility - hence my reference to "totally off".Many appliances have the mains filter before the appliance;s ON-OFF switch and therefore the L-E, N-E and L-N capacitors in the filter are in circuit at all times including when the appliance is turned OFF.(assuming that the appliance really was 'totally off') I can but presume that we must, again, be talking about 'leakage', through stray capacitance or whatever - not the equivalent of continuity through a lamp filament.
