decor end panels
28 Jul 2010
Berwickshire
what is best? decor end panel to the floor or stop at unit base then a kick board...........
help diy widow :rolleyes:
I did my island unit & end of a run, using decor panel to the floor, I thought about running a plinth round the bottom, didnt look good.
Im a diyer not kitchen fitter
Normally they go to the floor to give extra support, but do not cut until units are at the correct level and feet adjusted.
Decor end panels look much better down to floor, it also is stronger than having a piece of plinth there,which with the way B&Q cabinets are constructed (which are great) the legs position makes the plinth level with the side panel of cupboard
I agree decor end panels look much better going to the floor.
B&Q also do coloured end panels for their kitchens which are the same size as the unit end panels for end of runs. I always set the legs at the side in another 30-40mm so the plinth looks the same as it does from the front. ;) ;) ;) ;)
