HI
I am in the process of fitting a B&Q kitchen. I have a question about the base end support panels.
The Panels supplied are 570mm wide (the same width as the base unit carcas itself). I was under the impression that the end support panels were supposed to be 600mm wide so that when fitted to the end of the unit, they sit flush with the line of the cupboard doors.
Also, I expected the end panels to be oversized so that they could be scribed to the floor and the wall.
Have I misunderstood the function of these panels or do you think B&Q have supplied the wrong panels?
Any help would be gratefully received.
Cheers
(just to make clear I am aware that you can get Replacement Base End Panels, which are pre drilled coloured replacements for the standard white ones supplied and that these would obviously be 570mm. This is not what I have in this instance)
Cheers
