DNO question, new supply
Cant help with hire company's but your friendly DNO man may be able to help.
Haha, interesting. Weird how they would abandon the cable. Is that normal practice.
Any cable that no longer supplies any load must be made dead as close to it's point of supply as possible!
It may be worth hiring a cable detector and having a search.
Cable locators are generally designed to locate live cables that are carrying some load. So looking for an abandoned cable with no load on it will be a rather difficult job without the use of an appropriate signal generator. (oph and knowing what you are doing)
I wonder where the "third drop wire"
If you do not know what a 3 wire split single phase supply is, I would suggest you do some research!
Please note it is the ABSOLUTE duty of the DNO to get the necessary legal permissions to allow them to install their equipment on private property.
No matter what amount of money you pay them it remains their equipment.
Any advice to the contrary is totally incorrect and could lead to increased costs or legal difficulties. By all means let adjacent landowners know what you are doing but that is as far as you can go!
In the case of a cable the DNO will usually seek an easement that includes a capital sum payment to the landowner and an absolute legal right of access to the cable "ad infinitum".
Possibly a Metal Detector?
Could do as well as finding every other bit of buried metal! (though you might find a treasure trove which could pay for the supply)
P.S. see my edit above
I know what split phase is, no issues. The question was asked where the 3rd supply goes, and it's to the steading. This is why I believe no supply ever up at the cottage.
I have no need for any special requirements just a single phase supply. There was mention of 3 phase heat pups earlier in this topic. But I've decided to not go for this.
That makes total sense, but how does it fit with what you were saying in a recent thread? You didn't seem to see any great problem with the fact that a cable which had ceased to supply street lighting a decade or more ago had been left, live, with free taped-up ends, on the side of someone's house (where some foolish person injured himself by sawing through it!). That cable clearly had not "been made dead as close as possible to its point of supply" for at least a decade after it last supplied a load.
Kind Regards, John
I didn't have a particular issue that it was taped up, as that is how DNOs do it! I NEVER suggested that it being live, or that it had been left in place if dead, was acceptable.
I just, on that thread, didn't point folk to where the DNO had "failed", but suggested they find it out for themselves!
I also DID point out that just because it was taped up only meant that it was taped up and not live or dead which some seemed to suggest was the case.
I didn't have a particular issue that it was taped up, as that is how DNOs do it! I NEVER suggested that it being live, or that it had been left in place if dead, was acceptable. ... I just, on that thread, didn't point folk to where the DNO had "failed", but suggested they find it out for themselves! ... I also DID point out that just because it was taped up only meant that it was taped up and not live or dead which some seemed to suggest was the case.
Hmmm. I'm not sure that the 'taped up' was, in itself, the main issue but, rather, the fact that a live cable with an unterminated end had been left stuck on the side of someone's wall for a decade! As someone (I think EFLI) said, it seemed comparable to him leaving an unterminated live cable half way up someone's living room wall. Most of us were fully in agreement that to take a hacksaw to a fat electricity cable without taking steps to make absolutely sure that the cable was dead was an extremely foolish thing to do, but there also seemed to be suggestions that the DNO was not 'at fault' at all!
Kind Regards, John
Can you get a split-phase supply from your farmer neighbour's existing transformer? A 460V:230V transformer will cost around £7k, but might be cheaper than all the HV work.
I believe the cable run is too far for LV
Even at only 30A or 40A per phase? (assuming you're not heating the place with electric).
Heating will be oil. Only cooking and standard stuff is Electric.
I'm just going on what DNO man said. We will see what quote comes in, then I will see what options I have,
sell the Mrs.
Pictures, please.
We like pictures! ;)
