Hi All
Hope someone can help
I have built a stud wall which had fairly limited space for the door opening due to various units/obstacles.
The door is for a new downstairs toilet, and will be non standard shape - one of the corners is lobbed off due to the stairs.
I was hoping to use a standard off the shelf flush lining and door, and make the necessary adjustments where required (cut the lining down and make it fit the angle, then cut the corner off the door and shave the inside edge)
However, the opening that I have left is 800 x 2100mm (without the lining). When I take into consideration off the shelf measurements, a 32mm lining will leave me with an opening of 736.
The question is, am i better spacing the lining to fit a 686mm door, or cutting down a 762mm?
Any input appreciated.
Thanks in advance!
Thanks in advance!
