i have an old house, and are just in the process of putting in a new kitchen, ive wired in a cooker point for the new hob which is ok, as its on its own supply. No problem there. The cooker however has a plug top wired to it which i will cut of and wire to a fused spur to keep it neat and tidy. But the house only has one circuit for the sockets so everything is on this one circuit. i know not everything will be plugged in at once and pulling max load, i have had no problems in the past but had a gas hob, and the old cooker wired to the cooker switch which will know have the hob wired to it. But will the cooker wired into the ring main present a problem the cooker rating is 2.2kw. And if so what would be the best solution, apart from a rewire. Thanks for any help much app [/b]
