Usually metal boiler pipes are well earthed, either directly or indirectly via the boiler boiler and any connected electrical parts like the pump, so it maybe that you are becoming charged up with static electricity which discharges to earth when you touch the radiators. If so, once you have 'discharged' touching the pipes again immediately won't result in a further shock. (For safety sake, I'm not suggesting that you try this, just that you might have noticed it already)
That doesn't explain why it only happens when the pump is running though. Pipes can become live, especially if the system has isolating plastic pipes that stop earth continunity. Maybe a cable has become damaged under the floor because it has been in contact with a hot pipe making it live. If you have an RCD's in the consumer unit feeding the supply to the heating circuit, it should trip if a leakage to earth via you is detected. If you have one, now might be a good time to test it using the test button.
The pump should have an earth connection to safely conduct any fault currents away to earth, the wire may appear connected, but the main earth connection may not be satisfactory.
The only way to be certain is to have your earthing system and wiring insulation checked. This requires specific instrumentation and the knowledge to use it properly. If you think the radiators are "live" get it done immediately.
