Household insurance wouldn't need to if it's a contractor wot dunnit.
Might do - vicarious liability and all that. Unlikely, but...Household insurance wouldn't need to if it's a contractor wot dunnit.
Indeedy...Or worse, breaking the gas supply line followed by cutting a live cable !!!
But the barbeque factor has to be considered, especially if you happen to in the locality at the time.That is only local to the hole,
How about a " Back up Portable" Generator
They seem to work for the Local Burger vans.
Differences there may be, but both impossible are.
If a tunnel you want , a mole you need.
It's not impossible to push pipes under roads, I've seen it done many times.
That's right. Easy when you know how.No moles were used - they just pushed the pipes through the ground - Watson was very clear about that.
