Good point... maybe it’s on its own circuitIf it is a spur from a ring in the house having a double socket and a FCU on the end of it is non compliant.
That should be very easy top ascertain by looking at the consumer unit and seeing if there is a separate breaker for the garage.Good point... maybe it’s on its own circuit
It would. I suspect that it may well prove be a dedicated garage circuit, quite possibly a 2.5mm²/20A radial - in which case it would be compliant, circuit-wise (and would allow the OP to add sockets). but leaves us wondering about the seemingly very odd (and susceptible to mechanical damage - so maybe not even complaint!) location of the (we assume lighting) FCU.Be interesting to see the completion cert. It would be odd to find non-compliant work on a house that is not yet completed.
Would that be in the same way that it would be odd to find any Building Regulations contraventions in newly built houses?It would be odd to find non-compliant work on a house that is not yet completed.
I agree, on both points - but all we can do is guess and speculate. I would suggest that someone capable of locating that FCU where it is, in a 'hostile# environment like a garage, is probably 'capable of anything'!I find it hard to understand why the cabling would be as it is if the supply doesn't come in at the FCU. Whether the socket is protected by the fuse is, of course, impossible to tell.
As has been said, if the supply to the garage is a spur from a ring circuit, then not only are your options very limited, but what you already have is probably non-compliant with the Wiring Regulations.
Kind Regards, John
Kind Regards, John
Fair enough - but the fool who installed that FCU where it is presumably did not know that you would be 'protecting it' with kitchen units.... I’ll investigate when I move in as to how it is wired and it’s location on the ring or whether it has its own circuit. Not too worried about the location as it will be well protected by my new kitchen units...!!!
Where are you going with this?Would that be in the same way that it would be odd to find any Building Regulations contraventions in newly built houses?
May or may not be a bit of untidiness by the builders, who tend not to be allowed a lot of time. Not rocket science for the owner to get rid of it.
Whatever that is (a splash from some over-enthusiastic mixing?), it does not make the wall shoddy. The wall looks quite well done, actually.
Hardly a hanging offence.
Probably the usual NHBC one, whose value vs paper is not affected by, and does not cover, a bit of wood left behind, a bit of soiling on the inside of a garage wall, or cables installed in full compliance with the Wiring Regulations but not precisely parallel to the edge of a wall plate.
I think you are overreacting.If work looks poor that you can see just makes me wonder what work you can't see is like?
I must be a tad old fashioned. I expect new houses to be well-built to relevant standards. If they are released for sale with major faults several people are not doing their jobs properly!
If the problem is not with the system, per se, but with people not doing their jobs properly, changing the system will only create new opportunities for people to not do their jobs properly.If the existing system cannot be trusted, it needs to be changed.
