We're on with some work at home and would like to run a gas supply to a fireplace but cap it off for now as it's will be a solid fuel fire. This would allow us to make it a gas appliance at some point in the future.
The plumber has said it can be done and left at the fireplace but it also needs to be capped off at the incomer end too i.e. before it runs beneath the floor screed. In essence there would be a dead pipe beneath the screed until such time comes that gas may be needed to the fire where connection would be needed at both ends.
Is he correct in his approach? Can it not be a 'live' supply and just capped at the fireplace end with an isolation valve?
I know he is qualified and I'm not, but I just wanted a second or third opinion on what you would do if you were asked the same question.
