Fixing Pipe Covering
3 Sep 2014
Essex
Hi, Unfortunately we have copper pipes running down the wall and I want to cover these with
pipe covering 300mm wide which will cover both pipes. Question is, how do we keep this length
of plastic upright /attached? It is right next to a door frame so I suppose we could use superglue
but that is obviously not the right way to go! The cover does not clip over the pipes tightly which I suppose if it did it would keep itself in place. It is not overly big though, just right.
Do you really mean 300mm (about a foot) wide?
Most pipe covers are around 70mm or so.
Thanks, I can see what your saying and I saw the link but unfortunately the cover is slightly loose and so I am thinking if I could add on or attach something to the side of one of the clips so the fit will then be tighter. I don't believe in botching normally (do a job well, do it once !) but it looks like I will have to.
I reckon a little sploge of paintable mastic on the edge of each clip should do it, silicone would be OK but if it gets on the wall decorating next time might be a problem.
