flue clearance question
19 Feb 2009
Devon
afternoon all, when a flue disharges above a flat roof I understand it should have a minimum vertical clearance of 300mm but what about if it disharges close to a flat roof but not directly above it? In this particular case the flue is about 600m horizontally from a flat roof. I'm guessing that the 300mm vertical clearance still needs to be met - is that correct? TIA
The 300 mm above a flat roof is to prevent the flue becoming blocked by a build up of snow or leaves, so if it's not above the roof you shouldn't have to worry about that. Your installer will be best to advise you.
thanks sooey but it's a long story this one. The flue is my neighbour's and it's already in position. I extended a flat roof (with full planning permission/building regs etc) so there is now a flat roof below the flue. The 300mm clearance requirement is not met so there is a problem. Before I get into further discussions with my neighbour I'm trying to work out if the flue was incorrectly positioned even before I extended the roof. Before I did this work my neighbour told me that on their annual British Gas service visits the engineer always made a note that the flue position was not to regs. If this was the case it helps with my argument that my flat roof extension has not created a problem, it's simply exacerbated a problem that was already there.
before we comment on the flue we need to know the boiler make and model so we know if it is room sealed or open,
kirkgas, it's an Ideal Classic NF60. 18 years old so perhaps it will blow up soon and they'll have to replace it, with the flue properly positioned.
