Having replaced the fuse in the main switch on my oil fired central system the boiler works fine so we have hot water, however the water is not being pumped around the system.
I made the assumption it was the pump and replaced it however still no go, have today given old pump mains feed and it works fine. I have found there is no live feed to the pump ( terminal 4 on appliance terminal block )
