- Joined
- 6 Dec 2005
- Messages
- 1
- Reaction score
- 0
- Country
HI,
I've moved to a new house and the previous owner has wired the garage using tinfoil and bubblegum.
Can anyone tell me if my scheme to replace it is O.k
1. Run 6mm2 3 core SWA from CU surface clipped to exterior brick work for 10 meters the buried underground for meter before reaching the garage. Protect this run on the house CU with a 40 amp MCB
2. Install a secondary "Garage" CU with a 6amp MCB fro the lighting circuit. (3 x flourescent tubes wired in 1.5mm2)
3. wire a socket ringmain with no more than 8 double sockets in 2.5mm2 twin & earth and protect at the garage CU woth a 32 amp MCB. (The garage power is needed for small current low voltage transformers for hobbies and 1 x 1kw oil filled heater)
My other question is, would it be o.k to bury SWA under concrete without some form of conduit for protection.
If conduit is needed what type should I use?
Thanks in advance
Thanks in advance
