- Joined
- 14 Jul 2004
- Messages
- 3
- Reaction score
- 0
- Country
I have just installed 4 halogen spotlights in my garden. The instuctions suggest either wiring into a 3am spur or a suitable plug and the use of 1mm T&E cable.
I have in effect created a radial circuit by running all 4 lights in line off one plug (if that makes sense). The idea was to then to plug into a mechanical timer unit.
Questions I have are:
1. Is a 3 amp fuse sufficient if I have more than one light going through the plug.
2. It appears that I am overloading the timer as I have now bought 3 (one works perfectly on an internal lamp) and two have failed to switch off at the desired time, when used. The details with the timer say it is rated at 13 amps (resistive loads) and 4 amps (inductive loads) - is this the problem.
3. I want to extend the 'radial' circuit by adding two further lights - can I? Will I need to upgrade to 1.5mm or higher?
So many questions - so little time!!
Thanks in advance for your help and advice.
Russell
Russell
