ban-all-sheds said:
Petrol gennys are much cheaper than diesel ones of the same rating, diesel is rather noisier and much smellier.
Most of the cost of petrol is tax. You can't get "agricultural petrol" the way you can with diesel, so if you're going to use it a lot, the cost of petrol will overtake the cost of buying the thing pretty soon (and conversely if it's used for 2 hours a month, that won't happen).
I once calculated that using a 2.2kW petrol genny at half power costs around 50p/kWh in fuel, so you aren't going to use this instead of the grid!
And petrol was about 75p/l at the time, if I remember rightly.
So if you are going to use it a lot (several hours a day) and you can get hold of red diesel fuel, and you can afford to buy one, a diesel would be cheaper in the long run. Otherwise, sadly, petrol it is. I suggest checking the availability and price of red diesel as the first job - you may not need to go any further down that path!
Note that most generator endurance is given as time on half load - which suggests to me that they aren't happy, or are less efficient, if you run them close to full load. Be careful that some of them have silly fuel tanks that only take 4 or 5 litres - you want one with the largest tank you can find (15l seems to be a common "long run" tank size). Note that running your own 45 gallon drum of petrol into the generator's tank and rigging up a float valve to top it up automatically would be against the Petroleum Regulations!
How are you planning to connect this to the house, by the way?
Good luck, and let us know how it goes!
Cheers,
Howard
