BTW - I don't suppose anybody has a copy of BS 7909:1998 they'd like to photocopy & send to me?
Sorry no, but if anyones interested I have a form in word format I use to log test results. It saves messing up the proper forms.
Are you supposed to switch the earth in the changeover switch, or have a rod permanently in parallel with the supply earth?Qedelec said:I worked out that to fullfill the regs it would need its own earth spike.
Which means a switch in the main earthing conductor, which I thought was a no-no?The earth rod should idealy be switched as well
They are busy and important people - I wouldn't want to trouble them....but I would check with the REC.
You can pay more if you want to: http://www.generators.co.uk/briggsstratton/generartors.php#bst9200mQedelec said:the change over switch worked out at £100 approx.
a rod in the ground isn't really any different from a pipe in the ground and you connect those to the suppliers earth all the time. So i really can't see any problem with having a rod permanently connected provided adequate cable is used.ban-all-sheds said:TN-S: - Dunno. It's what I've got, of course....
Wood.... trees.....plugwash said:a rod in the ground isn't really any different from a pipe in the ground and you connect those to the suppliers earth all the time. So i really can't see any problem with having a rod permanently connected provided adequate cable is used.ban-all-sheds said:TN-S: - Dunno. It's what I've got, of course....
plugwash said:one thing i've often wondered is if gensets are ever configured to start and take over some of the load when power demand exceeds a certain level.
i'd think such a setup could for example be used if a site was having problems with overloading thier service occasionally but either couldn't justify the cost of an upgrade or couldn't get it soon enough.
Lectrician said:One site we did ran the generator from 3pm to 3am, when all the refridgerated lorries where parked up, and plugged in (32amp 3ph each). The mains supply was just overloaded, and the timescale for replacement was months!!
