Chris.J said:Instead of one big c/o switch, how about feeding the ccts. you want backed up with spurs, and using a panel of small c/o switches, after the CU?
You would need to switch both live & neutral, and could feed the Genny in via it's own small CU with RCCD & MCB's. Genny frame "earth" would = existing supply earth?
My Genny is "floating neutral", and IMHO, thats what you want.
I've bonded "neutral" to earth at the supply side of the RCCD; house is TT.
I'me not sure if FN is normal for portables sold here, or whether non FN's are allowed under CE regs?
Afaik floating generator neutral can be classed as protection by electrical separation subject to the conditions laid down in the IEE regs.
You have bonded Neutral and Earth together before RCD, please can you explain?
