.....but will need shortening, as the incoming side won't have enough play in it to move it down that far. Shortening the incoming pipe is going to be a job for the gas transporterIt has to move down 12" to allow the runners for the New Garage door to be fitted
The Main gas feed or the Feed to the house from the meter will remain in place
Afraid not it has to be loweredAn RGI with the right tickets could swing the meter as far as it can go to the left of where it is now, then re-pipe it. Would this work ?
if you mean that the pipes are fine where they are and that only the meter and the meter governor need to be lowered yes its no big deal , but as already advised meters in garages are usually ther to stop them getting hit by cars etc
I thought that any pipe work before the meter outlet must be done by the GT. Regardless of MET1.yes it can be the valve with the red handle to the left of your pic with the yellow label an RGI can close that and work anywhere upstream of that depending on his competence, all you need is someone that knows what they are doing its not a big job Tony will be along in a minute to quote you for it
Hi Terry so how do you remove a meter when you are going to solder onto the outlet of the meter if you can not work on anything before the meter outlet ?I thought that any pipe work before the meter outlet must be done by the GT. Regardless of MET1.
