Having had two of the 'original' Drayton Digistats which worked very well, I've now had it with the latest model that tries to guess whether the heat should be on or not and gets it wrong most of the time.
What's a recommended digital thermostat, 7 day programmable, that doesn't have built in intelligence, or if it does you can turn it off so that the call for heat works at the temperature you actually set it?
Thanks!
Thanks!
