Hi guys. Whats the best way of hanging a rad when the pipework is already there and the rad valves are already on the pipes? The rad was removed as wall had to be replastered. The thing is, i need to be spot on when i drill the holes for the rad brackets as i have to use spring toggles therefore if i make a mistake i can not drill another hole nearby otherwise the spring toggles will just come off under the weight of the rad. Thanks as always for your time and advice.
