Heated Towel Rail Energy Regulator
19 Jan 2006
Wiltshire
Hi, my parents are going to install a 400w heated towel rail in their bathroom soon, I thought it would be a good idea to get an "energy regulator" fitted outside of the room, for the purpose of saving energy during the summer months etc.
Am I overlooking something, or are these just overpriced dimmer switches with a crude scale drawn on the front?
Thanks for your response R F, that would be another idea, by controlling the time scale it's on for, rather than limiting the current drawn.
I guess the linked timer switch is similar to those push timed light switches you find in flat stairwells. (except not mechanical).
Am I correct in assuming that the energy regulator works in exactly the same way a standard dimmer switch does?
Dont know. I've not seen one.
All I can assume is it is some sort of thermostat system.
A dimmer would save no power. It would just mean the towel rail takes longer to heat up
Do you have a link to this 'energy regulator'?
I forgot to mention I realise the one in the link would be unsuitable for the job as it's hugely underrated - I have seen another rated at 850w elsewhere, but with no other spec.
