- Joined
- 27 Feb 2005
- Messages
- 3
- Reaction score
- 0
- Country
Every few days - when the heating has been on for a few hours - all hell breaks loose. There are banging noises and water floods out of the header tank overflow. The header tank water is hot. The radiators and pipes also seem very very hot. 23 yr old Flamingo Boiler & no previous problems. Water feed not blocked (can drain radiators at high speed whilst header tank refills). System can go for days with no problem and boiler stat seems to work (it does switch boiler on and off although rads etc still seem very hot on low setting. Pump turns and seems OK. I wondered if thermostatic valves had all closed causing pump to force water down overflow but that's not so on latest episode (I have removed 3 of the valve tops to ensure rads are always open). Motorised valve seems to work OK - it cuts heating off when up to temp. Once problem happens it recurs until I get all air out of system (seems pump can run "dry" after an episode causing same problem again). Can take a while to get air out again. But what is causing it in the first place? Always happens only after system be running for a couple of hours. Any ideas gratefully received! Thanks
