This fault exists with the newer wall thermostat and it happened with the older dodgy one. When the thermostat clicks on sometimes the boiler does not fire up for the heating. Its an intermittent fault and i have the boiler set to on at all times. When the heating does not start i need to go to the boiler, switch it to timer, it fires right away, then back to ON and it stays on, usually it works for the rest of the day without issue.
I know the wall thermostat is ok because its a new honeywell digital one. Does this look like its boiler related and will i need to get an engineer to look at it, im just thinking if its an intermittent fault it might be hard to troubleshoot. Does anyone know what the problem might be?
