I have been in my house for a year. During that time I have had no problems with the boiler which is a combi for my hotwater and CH. I joined Homeserve as they give you a free service once a year and yesterday a Corgi engineer came out to service it giving it a clean bill of health.
The next day my pressure was at 0 and I could not use CH or hot water. My CH has been off since May and the only reason I knew it was not working is because I tried it before I saw the pressure was at 0. When I saw the pressure was down to 0 I added more water from the filler loop, taking it back up to 1.5. I then tried CH and hot water and both were working again and were stable. However, when I turned off the CH, the pressure dropped again to O. I again filled the boiler to 1.5 and tried the hot water. It is stable while it is running but after switch off over the course of about 10-20 mins it drops to O. I phoned up Homeserve and they sent out another engineer from the same company and he refilled the boiler and ran the hot water and again the pressure valve was stable. The hot water was turned off and he waited for a while but had to go to another job. After 10-20 mins the pressure then dropped again to 0. I phoned them back and they are now saying that I must have a leak but there were no problems yesterday!! I have looked over the whole house and can find no leak(unless under floorboards or in walls) and it must be a massive leak to take 20mins to empty boiler!!!
After he had gone I refilled the boiler and ran the CH for 2 hours with no drop in pressure at all. Even when running the hot water at the same time there was no drop. However, as soon as it was turned off the pressure went to 0 again within 20 mins.
Please help. Basically I need to know could the service engineer have caused this by knocking something in the boiler? He gave it a full service but did not touch anything else.
I have looked on DIY sites and the options are:
1 A leak - I have checked and cant find one.
2 Pressure relief Valve - have checked this and no water coming out.
3 Expansion vessel - don't know anything about this but could this be possible?
4 Air in system venting through automatic air vent - could this be possible?
5 Diverter or diaphram?
Are any of these possible. I have checked the first two. Would really appreciate any advice at all. Thanks.
