Hello
I am currently trying to help a customer with her boiler, the gas council number is 4733316 (halstead ace, combination boiler)
At the moment is all off, no heating or hot water.
The fan does not work, but the pump works.
After investigating I found that it is not the over heat stat, or the flow switches, the air pressure switch is also okay.
I discovered that the pump live was showing as neutral, and the neutral was live, at this point I though it was a neutral fault so I had a look at the polarity which was fine, I then checked all the neutrals and live on the pcb which was fine.
The pump is connected to the pcb, and the voltage is sent from the pcb to the pump, I am suspecting that it has to be the pcb. What do you think, any comment would be great..
