hoover am 110 washing machine
1 Nov 2009
Lancashire
I have a fault with a hoover am110 washing machine that is not heating water correctly.
It will run all programmes through to the end,calling for water,spin and drain as per selected programme.
However on any programme the element is switching on for only a few seconds then switches off and fails to heat the water to correct temperature.
On investigation the multi-contact switch(timer programmer) seems to be stopping at the wrong intervals for heating.
Is there a master reset for the multi-switch.
Economy button is not selected as i know this limits water temperature.
Drum ntc thermistor has been tested and is ok.
Any help would be appreciated.
Cheers
