Hot water back on after 27 years (now i have a boiler installed) but it's milky coloured. Do i let taps run and if so for how long? Is it likely not just air bubbles?
The water inside a combi is at mains pressure. Cold water, under pressure, can hold more dissolved air than the same water, either hot, or unpressurised, or both.
The water in the combi is heated up.
As soon as it emerges from the tap it is unpressurised and the excess dissolved air forces its way out.
