Hot water issues Worcester 24cdi
Discussion in 'Plumbing and Central Heating' started by simonjrwinter, 17 Dec 2011.
  1. simonjrwinter
    17 Dec 2011
    5
    Thanks Received:
    Essex
    Country:
    My daughter has just moved into a flat with an old Worcester 24cdi boiler. The CH works fine as did the hot water (really good and hot) until a few days ago when the water would run barely tepid.
    I contacted a Ch engineer who told me the heat exchanger could be blocked (a common problem with these so I'm told)
    I have just replaced the heat exchanger and renewed the diaphram in the diverter valve. The water is now much hotter, but even with the water control turned up all the way it is still not REALLY hot (you could stand under a show at this temp with no cold and it would be quite comfortable) is there anything else I should check? Any advice greatly appreciated
    Simon
  2. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    You must check that the rads are not heating when the hot water is on.
    This is best done when the rads have been off for a while and are cool.
    If they do heat, then the diverter valve is passing and requires repair or replacement.
    Remember a 24cdi will only raise the water temp by 35C. Not great when the incoming water temp will be in single figures.
  3. simond
    26 Oct 2004
    5,213
    Thanks Received:
    460
    Surrey
    Country:
    Really?????? News to me. :LOL:
  4. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    OK at 9ltrs its 38deg and at 10 its about 34 so whats your point?
  5. simonjrwinter
    17 Dec 2011
    5
    Thanks Received:
    Essex
    Country:
    When I was dismantling the boiler I did not remove the hot water thermistor, but it may have been dislodged. Would re-seating it with new heatsink compound make any difference?
    Simon
  6. Agile
    26 Jun 2004
    61,288
    Thanks Received:
    4,285
    London
    Country:
    I think that Simon's point is that a a flow rate of say 6 li/min then the boiler is capable of heating to water to a higher temperature!
    Tony
  7. simonjrwinter
    17 Dec 2011
    5
    Thanks Received:
    Essex
    Country:
    Yes, before it went wrong and I "fixed" it, the water was propery HOT as it should have been. Now it's not to hot to hold your hand under.
    Simon
  8. BARNY78BG
    18 Dec 2011
    131
    Thanks Received:
    21
    Mid Glamorgan
    Country:
    did your daughter move into the flat recently or a few months ago before the temperatures started to drop?
  9. simonjrwinter
    17 Dec 2011
    5
    Thanks Received:
    Essex
    Country:
  10. BARNY78BG
    18 Dec 2011
    131
    Thanks Received:
    21
    Mid Glamorgan
    Country:
    temps and flow rates need to be checked per manufacturers instructions before replacing parts
  11. simonjrwinter
    17 Dec 2011
    5
    Thanks Received:
    Essex
    Country:
    OK, but if it was working fine before what would that acheive?
  12. Dan Robinson
    1 Jul 2007
    43,965
    Thanks Received:
    7,134
    Hertfordshire & London
    Country:
    Knowledge and facts dear boy, knowledge and facts.
  13. Blooflame
    22 Nov 2009
    189
    Thanks Received:
    29
    Warwickshire
    Country:
    I presume it's the same temp at the taps? Wonder if you can isolate dhw out (gate valve) and check there is definitely no flow at the hot taps? If there is then the mixer valve seal is kaput and mains being drawn in
Loading...
Share This Page
