Terminal 3 should be connected to common when
calling iirc
calling iirc
No, thwater temp needs to be higher than the cyl stat setting, this would then send power down the yellow to the grey on valve, HW needs to be set to on at prog for this to work.Thanks for the additional detail.
From the Cyl Stat there is a yellow wire that is connected to the Valve grey.
Do I need to let the hot water cool down till is moves to heating only?
