OK every setting now appears to be working as expected.
I quickly tried the old prog box which we decided was broken and it was and was doing weird things so it was a combination of a faulty prog box and the incorrect wiring of the prog box.
Guys a big thank you to you all. I am really chuffed and I now know a little bit about heating systems which is a lot more than when I started this
As stated earlier you have a wire missing, what is being suggested is to use the 'green and yellow' wire in its place, or install a new wire
At the programmer connect it to the HW OFF terminal thats no 1
At the terminal box connect the other end to the terminal holding the grey and the 'yellow' from cylinder stat.
Also if you have fitted a new programmer have you checked and set the programme selector for a 'fully pumped' system
