i had The same problem with my hotpoint washing machine(flashing lights). first I wanted to change the board but then I came up with a better solution. basically just add the water manually where do you usually add powders. add 1 or 2 litre of water as you turn your program on. i did this and the problem was solved. i havent had the flashing lights even when i dont add water manually. hope this solutions works on yours too.
Hi my hotpoint washer dryer WDL540 work fine till the point end spinning. It does spin alright few times and suddenly a pull sound comes then all lights flash. While light flashing it stops working. Non of the button works.
