House Wiring, With Shower
8 May 2009
Sheffield
What consumer unit would anyone recommend and is the wiring correct below
Downstairs Ring Circuit B32
Downstairs Ring Circuit Kitchen B32
Upstairs Ring Circuit B32
Attic Ring Circuit B32
Downstairs Lighting B6
Upstairs Lighting B6
Attic Lighting B6
Cooker Cable 6mm Direct B32 (or not?)
Shower 1 Cable 10mm Direct B40
Shower 2 Cable 10mm Direct B40
1.5 mm Fire Alarm 2 Core Cable B6 (or not)
Can someone help me out on the MCB's, are they correct.
The consumer Unit will have two RCB's, and can the Cooker MCB be outside the RCB????
And any recommendations on how many MCB's on each RCB????
I hope this is not too much for you guys...
One more thought I have had, why not get rid of all MCB's and RCB's and replace all on a RCBO system, with each circuit having its own RCB... Would that be recommended?
Thank you guys..
You will need a split load 17th Dual RCD edition Consumer Unit
This needs to be done by an qualified electician and is notifiable under Part P of the biulding regs and requires an Electrical Installaion Certificate witha schedule of inspections and a schedule of test results.
