how to find a neutral
Status
Not open for further replies.
29 Aug 2005
Kent
hiya everyone could someone out their help me please,when i install a boiler etc and a new room thermostat is to be fitted it can be very confusing as to what wires are what,find the live no problem and the earth wire is normally used for a switched live,naughty and i have always tagged it for future reference if another person touches the thermostat.when i run a wire to a new location i make sure i install 4 core
please can someone help how do you get a true test to find the neutral i would be extremly grateful if someone could just clear this frustrating question up please.
all the best
gary
it amazes me that nearly everytime i go to wire up a new room stat or cylinder stat the someone has run a normale 3 core instead of a 4 core and used the earth wire as a switched live.
i put a small bit of insulating tape to warn other
all the best
gary
all the best
gary
all the best
gary
using the earth as a live is extremely dangerous and should NOT be done. you should have told them to use the right cable to start with. 3C+E
And now that electrical work is a controlled service in terms of the Building Regulations it is illegal for you to re-use a cpc as a switched live when installing new stats.
You have 2 options:
1) Rewire it properly
2) Walk away
Sorry, but that's the way it is.
Using the earth as a live conductor is not recommended and is dangerous. NEVER do this for that reason i am locking this post
If you are not sure how to carry out any task please consult a professional
Status
