Wondering if anyone can comment and help me out.
I have a 1000ltr thermal store which my solar thermal and heat pump store its 'heat' 9 or 10 months of the year these 2 systems provide all the heat for heating and our hot water needs in a 4 bedroom house.
However in the coldest months there isn't enough hot water available for a shower early in the morning 6am. at around 9am there is enough hot water again. I am now fed up of cold showers and want ideas on what i can do to have hot water early in the morning.
My ideas so far.
1. a 50l electric water unvented tank in the attic which feeds from the hot water from the thermal store. So the heater will only need to heat the water from 30c to 40-45c. i obviously only want the 3kw heater to run in the morning when its needed.
3. LPG Combi. so i dont have mains gas. could i use a lpg combi boiler for DHW only. again running the hot out from my thermal store to the combi. the combi would only need to be on in the early mornings so at most 30mins a day to heat from 30 to 40-45c~. would i be better off using the 47kg bottles, not sure how many of these i would get through in 2-3months? or get a smallish tank installed outside? This would also benefit us as if we have a power cut we would still have hot water as everything else in the house is electric.
so that my problem, any help would be much appreciated.
My ideas so far.
- Problem 1. I would need a bypass valve so that when the thermal store water is hot enough it doesnt need to run through the electric water heater.
- Problem 2. is a 50l tank big enough to serve 2-3 showers in the morning with roughly 15mins between showers?
- Problem 1. expensive to run
- Problem 2. running a new cable
- Problem 1. Most expensive to install
- Problem 2. on sure of ongoing costs of bottles
- Problem 3. bottles or having a tank installed.
