I only have 1 ring main...
1 Feb 2010
I went to add a double socket spur into my upstairs ring main earlier and have just discovered I have 1 switch in the cu for 1 double socket downstairs (no idea why), and then the hob/cooker is on another. But everything else is on the 1 32A 2.5mm ring main! Thats 12 single sockets and 8 doubles, is this ok? It hasn't tripped once in 2.5 years of heavy use at certain times!
Its not unusual for older houses to only have one ring final. It is not ideal for today's loads.
You should consider getting a new ring for kitchen/utlity next time its being refurbed but you're probably OK if you haven't had any trips and are not planning to add any significant extra loads.
were having a semi refurb now lol, just not touching the kitchen its the only part thats new! typical i guess! oh and i suppose sockets clipped to the wall 1 cm off the floor isn't a very good idea just found 2 of them?! I'd love to know who did the wiring on my house!
ill just take the old, if it aint broke don't fix route for now as you say!
That sounds like my grans house. Cheap re-wire in the 1970's replaced the cables with PVC and all the BS 546 sockets with BS 1361s. Would have been fine with straight outlets but of course modern sockets are different and they reused the old backboxes.
I remember one of my sets of grandparents got around the problem of cable entry to plugs very cloe to the floor by mounting the sockets upside-down.
Anyway if you are refurbing most of the house it should be possible to split the rings without interfering with the wiring in the kitchen itself.
