Anyone very familiar with this range of boiler?
It's an old one, fitted around 12 years ago. I am trying to determine if I have a flow / blockage issue or if it's normal to cycle so soon and often.
After it comes in it last around 15mins before stopping. Finger touch the flow seems to have reached its stat set peak. Return however is still quite cool, perhaps half as hot. It then cycles 2mins on 1min off roughly, until it's met its demand.
The boiler is serving a 3 storey with 21 rads, all but the ground floor and landings have trvs. I've opened the valves fully on most on the ground floor to try and alleviate the issue. No luck.
Pump has been removed and inspected, it's turning fine, a little black cleaned and installed back on speed 2. It's a grundfos 15-60. On 3 it created cavitation.
Boiler has had a new pcb, fan and air tubes changed, electrode done too.
Do you think return is slowed down by a blockage or is this typical behaviour of this un modulating boiler?
