I
ihateplumbers
Hi, I have an Ideal HE30 which is displaying the L-F fault. I have measured only 110v dc at the gas valve(instead of 200v i believe) and there is no voltage going to the igniter module except for near the end of the sequence when 200v flashes up for about a second.
The boiler goes through its starting up procedure with the pump running,the top fan running etc and the circuit board can be heard making all sorts of clicking relay noises.The board is the orange type.
I have checked the resistance of the thermisters and they seem to be reading ok.
The only other thing is the ignition module.I cannot get any resistance across the input terminals.Is this correct or does this mean its goosed?
My hunch is that's its the circuit board that's causing it but have any of you guys any ideas as to other checks i can do before ordering a replacement.
Thanks for your help.
Regards.
Regards.
