i have the ideal mini c28 combi boiler on a sealed system.
i was bleeding 2 of the rads upstairs. no water came out of either of them. i was going to re-pressurise (top up) the boiler but i noticed there was no filling loop, or any space for a filling loop.
i turned the blue handle underneath the boiler which i thought would let water into the system. the pressure bar didnt move from 0.5 bar. instead it went down to 0!!
the boiler is now not working. i still have hot water. if i run the hot water then the boiler fires up and the pressure increases to 0.5 bar again. when i turn the tap off, it goes back down to 0. so basically i have no central heating system, but hot water.
the pressure my boiler was at before all this happened was 1 bar. im not too sure on the manufacturers guidelines.
also, the digital timer the boiler is attached to seems to have gone dimmer and even disappeared for a few seconds.
can any one offer me any help? i have no central heating!!
edit: i have checked the PDF manual online but i couldnt see any troubleshoot relevant to my problem. i also couldnt see any thing relevant to a filling loop.
