Well it's really up to you, but I'd go for at least one more than you think you need.
For a bedroom, one either side of the bed, and then two or three elsewhere, if you're going to have a TV, wall mounted or otherwise, take that into consideration.
Don't have them on the skirting board, terrible idea. If you're redoing the whole house, put them at 450mm off the floor to the bottom of the socket, it looks odd at first, but it's so much more convenient than on the skirting
Hi
Thanks for the replies. Yes, we planned for an ariel and and electrical socket and ethernet cables to go behind the TV wall higher up. Specifically on this point, what height would you say the TV sock and ariel sockets should go, about 1.5m from the floor or slightly higher given that a good 42 inch TV will hide any plugs in that square area? I made the mistake of fitting my the TV so high that we now see the ceiling light reflection when watching TV at night, so dont want to make the same mistake again and also slightly awkard viewing height though we are now used to it. I think most installers say keep the mid point of the TV at 1.5m from ground.
Is the following item also worth considering? http://www.amazon.co.uk/gp/product/...rue&ref_=ox_sc_sfl_title_3&smid=A186AO9HIA45J
Some of my walls are block solid walls but will have plasterboard in front of it. Would this item best be used with a plastic back box or metal one and what size?
