I have a Potterton Suprima 60HE and recently the little red lock-out light has started coming on, sometimes the boiler would fire up and run for a while, other times it wouldn't. I've traced the fault to the Ignition transformer and the central pin is broken in the connector. I've found a site that sells the ignition transformer / ignitor assembly but what I would like to do is replace the connector on the end of the wiring loom as well. It is pretty corroded - it looks like there has been a small leak and water has dripped onto the connector - and could do with being replaced. There is enough spare wire on the loom / harness to allow me to cut the wire back, crimp on some new wire ends and fit a new connector. Anybody know where I can get a new connector from or what make/type of connector it will be? I don't want to buy a whole loom just to cut of the connector and then splice it into the old loom.
Thanks for any help
Paul
Thanks for any help
Paul
