OUR IMMERSION HEATER IS NOT WORKING. THE WALL SWITCH IS ON AND THE FUSE IN THIS IS OK
BUT THE WATER IS NOT HEATING. ANY IDEAS WHAT IT COULD BE AND WHAT I COULD CHECK AND ACTION I CAN TAKE TO REMEDY IT
Sounds like the element itself has gone.
For the hassle it will cause it is cheaper to get a new one they range from £7.49 - £10.99 (they do at screwfix)
you will also need a immersion heater spanner to undo it, but try and undo it by hand when you get it as the copper cylinder is easy to ruin.
Switch off the mains FIRST and drain the tank
