If I want some 15mm BS EN 1057 Type X, can I buy any make, from any supplier, or are some makes/suppliers more equal than others?
Ditto solder ring/end-feed fittings.
It may be a false feeling but the Black Label as widely sold seems slightly better!
With 15 mm its pretty irrelevant.
With 22 mm the same if only using straight lengths.
But if you are bending it then it always seems to me that some brands are more prone to rippling than others.
I rarely bend as it does not look nice although it gives less flow resistance for gas.
In fact I usually detemper it with heat before bending.
