Our tests were carried out on a total of 607 RCDs in properties owned by four Housing Associations and Local Housing Authorities in the UK. All the devices tested were of the electromechanical (voltage independent) type.
The tests were made on the load side of the RCD, as close as practicable to the device. Occupiers were asked to turn off all appliances such as washing machines, TVs and computers for the duration of the test.
Although it could not be guaranteed that all loads had been disconnected prior to the RCD tests, there was no indication from subsequent analysis of the results that the tests would have been affected by any capacitive loads that had inadvertently remained energized.
The initial test for the first 172 devices was carried out in alternate properties at one times (30 mA) and five times (150 mA) the rated operating current. This was to determine whether or not the magnitude of the initial test current had any significant effect on the failure rate.
For the remainder of the tests, each RCD was tested at the rated operating current of the RCD (30 mA) three times during the positive and negative half cycles of the supply waveform. The tests were then repeated at five times the rated operating current (150 mA).
Functional testing of the integral push button was carried out last..........
Of the 607 RCDs tested, a total of 23 failures were recorded, giving an overall failure rate of:
3.8% - including the six RCDs that had been shorted out.
2.8% - excluding the shorted out RCDs.
