Is this quote ok?
Discussion in 'Electrics UK' started by Isleman, 2 Mar 2012.
  1. Isleman
    3 Nov 2011
    21
    Thanks Received:
    5
    Hampshire
    Country:
    I moved into 3 bed semi about a month ago.
    The place has been build in 1960's but nothing been touched since.
    The electrics is outdated with just one socket per room and no consumer unit.
    As the budget is pretty low at the moment I don't mind putting some work myself like doing the channeling and the dirty work.
    I had a chap around for a quote but I felt it is too much .
    Here is the breakdown :
    Final Price: £5560
    £840 to be taken off if supplying own materials
    £500 to be taken off if wall chasing is done by client
    Price Includes:
    19 Double Sockets
    8 Pendants
    1 IP Rated Light Fitting (Bathroom)
    2 6” Flu Fitting (Garage)
    9 Switches
    1 Pull Cord
    1 4” Extractor Fan (Bathroom)
    1 Cooker Point /Extractor Supply/ Junction
    17th Edition Fuse Board
    Gas and Water Bonding
    Smoke Detector System
    Full NICEIC Certification
    Notification to Building Control
    Do you think the price is fair ?
  2. Iggifer
    8 Sep 2011
    3,883
    Thanks Received:
    468
    Warwickshire
    Country:
    to even be able to begin to say (which is near impossible anyway)
    need some more information
    how big is the house?
    how many circuits
    no immersion heater?
    just get 2 more sparks out to quote you, this will give you a much better idea of how reasonable this is
    • Thanks Thanks x 1
  3. riveralt
    4 Jan 2004
    4,020
    Thanks Received:
    597
    Country:
    Sounds very expensive - you should get at least three quotes - just make sure you compare apples with apples.
    • Thanks Thanks x 1
  4. sparkiemike
    10 Oct 2008
    284
    Thanks Received:
    27
    Hampshire
    Country:
    For Hampshire sounds about right!
  5. holmslaw
    12 Dec 2006
    5,841
    Thanks Received:
    400
    Country:
    • Thanks Thanks x 1
  6. Isleman
    3 Nov 2011
    21
    Thanks Received:
    5
    Hampshire
    Country:
    The house sizes are :
    8.20 m ( front to back ) x 4.85 m(side to side) = so roughly 40 square meters
    As for circuits I would say probably 6-7
    The immersion heater will be replaced by CH
    I will definitely have another people coming in to have a look.
  7. Isleman
    3 Nov 2011
    21
    Thanks Received:
    5
    Hampshire
    Country:
    No offense to you but as you are a sparkie I have the feeling that even the quote was 10 k you would probably say the same .
    I bet it doesn't take him more than two weeks to do this job.After paying the tax he still probably clears 3k . The whole income for my household per whole month is less than that.
    I don't understand this " for Hampshire is about right " . I think the charge should be for the amount of work being done and not for where the house is located.
  8. Chri5
    19 Jan 2007
    4,270
    Thanks Received:
    387
    London
    Country:
    Don't be nieve, more affluent areas will always be charged more, if a guy has a market rate for an area that others will pay, then that's what you get charged.
    As for his quote, in North London I'd charge about that for a 4 bed Edwardian on a street with house values at £500k.
    Mine would be (all double sockets) 4 for each bedroom, 6 for each recpt and kitchen, and one in each hall level. One central light per room and each hall, 4 spots in the bathroom and lighting in the kitchen TBA.
    For another £500 I'd put TV, phone and data in each room.
    On a £6k job about £1500 would be materials, allowing for flatplates in the kitchen, GU10 LED for spots.
    So for your area I'd say he is charging too much.
    Step back, you spec up each and every room, consider external lights, double switching for the halls and be as absolute as you can.
    Once a spec is near final show the same spec x 3 potential suppliers and see what prices come in.
    If you want to supply materials, say fittings only and allow them to sort cabling, back noxes, cu and the essential items that you wouldn't know what to buy (volume, type etc)- cable, cu, back boxes and misc items (grommets, screws, sleev, earth bonds, tube, trunking)- about £500
    As for reducing cost, a back box and chase takes 15 minutes (caveat that for different structures) a DIYer could take an hour per one, so is there a saving?
    Same with light switch chases, let the pros with a double grind cutter or years of bolstering experience do the job.
    Finally, why not agree to clear / vacate each room for 48 hours, offer to do the making good- the easier the job the less hours it takes.
    • Thanks Thanks x 1
  9. chivers67
    18 Nov 2008
    608
    Thanks Received:
    64
    Surrey
    Country:
    Have you been given a rough time scale? Seems a little pricey but without seeing the house (even with sizes) it's quite difficult. Is the ground floor wooden or solid concrete?
  10. holmslaw
    12 Dec 2006
    5,841
    Thanks Received:
    400
    Country:
  11. sparkiemike
    10 Oct 2008
    284
    Thanks Received:
    27
    Hampshire
    Country:
    You are free to get other quotes, and perhaps you should have done that before you come here complaining! For a 3-bed I would expect it to come in between £4K and £6K depending on the exact spec. Prices do vary from one part of the county to another, up norf prices to tend to be cheaper - that's just life. In my part of Hampshire on the border of Surrey and am busy so my prices are right for me! If things change and I find I am at home waiting for the phone to ring I will adjust prices accordingly.
    As for clearing £3K don't make the laugh - I wish! There are a lot of other expenses - fuel, vehicle costs, insurances, scheme memberships, tools etc etc
  12. Taylortwocities
    28 Jul 2006
    16,100
    Thanks Received:
    1,550
    Oxfordshire
    Country:
  13. Alarm
    18 Oct 2010
    8,970
    Thanks Received:
    529
    London
    Country:
    LOL using Pimlico Plumbers as a guide, most expensive going by far. And they charge to get materials the vans are hardly stocked.
    Last time I had a chat with one of them when doing the plumbers merchants alarms and cctv.
Loading...
Share This Page
