kitchen extractor - do i need one??
Discussion in 'Building Regulations and Planning Permission' started by littlestreatham, 24 Aug 2009.
  1. littlestreatham
    15 Jul 2009
    5
    Thanks Received:
    London
    Country:
    I am looking to replace the kitchen in my flat. One kitchen company told me that I HAVE to have an extractor. Others have not specified this. My flat is open plan and I have 4 big windows in the room plus 2 vents. Am I obliged under building regulations to install an extractor??
  2. ^woody^
    3 Sep 2006
    17,839
    Thanks Received:
    1,968
    West Mids
    Country:
    The kitchen replacement is not controlled works under the b/regs so you don't have to adhere to the fan requirement.
    But it would be wise to do so
    Windows don't extract stale humid air, but just push it around the flat
  3. wysinawyg
    13 Jun 2007
    17
    Thanks Received:
    Country:
    ^woody^ as you seem to be a man who knows about these things, is that still the case if you are doing controlled works such as electrics and gas as part of the refit? Or an RSJ to take out a structural wall?
    Or would the question of actually adding the oven/hob always just be incidental?
  4. huw169
    29 Apr 2005
    181
    Thanks Received:
    Hampshire
    Country:
    A mate of mine has just finished a full refurb on a flat he bought for rental.
    The only thing building regs checked when they came around was that the bathroom and kitchen had extractor fans - didn't even check they worked, just that they were there.
    May be different for rentals, but woody is far more knowledgable in these things.
  5. jeds
    16 Apr 2004
    4,093
    Thanks Received:
    526
    Country:
    Building control being involved in a refurb implies material alteration to controlled services or fittings - in which case different rules apply. But for a standard kitchen replacement there is no requirement to provide mechanical ventilation where there was none previously.
  6. ^woody^
    3 Sep 2006
    17,839
    Thanks Received:
    1,968
    West Mids
    Country:
    You would have to be creating a new kitchen room/space for the fan requirement to apply. If you are doing other work under a b/regs application, then the remit of the BCO is just to those works
    Part P would only apply to the extent of checking the actual installation is OK - ie if an extractor is being fitted it should be fitted properly, but there would be no requirement to actually fit one as part of other installation work
Loading...
Share This Page
