I have a small problem with the plumbing in the kitchen of my flat.
Currently the kitchen is a bare room, and I am soon going to start putting the kitchen in. However, I have a problem with the wast pipe running behind where the oven will go.
The pipe is a 42mm pipe, but there is only about 30mm gap behind the oven to the wall.
i know you can get 32mm pipe, which I could make fit by digging it into the plaster, which is quite thick, but was wondering if there was a better solution, or if reducing the size of the pipe would cause any problems.
It's only about 70cm bit of pipe I would need to be smaller.
What options do I have?
