I've got this rental property (1st & last..) approx 10 years old. Tenants are moving out. Did a pre-move out inspection and most of the upstairs ceiling light fittings look to have been overheating (brown to dark brown around the cream bayonet holders - half sphere type glass light fittings)
Tenants said the bulbs blew a lot and replaced most with CFL efficient bulbs (11 Watt I think). So I replace the damaged light fittings with surface mount and pendants where necessary. Plugged in the Dyson to tidy up and the MCB flipped on the upstairs lighting circuit.. What have I done!!? This is pre 17th so no RCD/RCBO on the lighting. Plugged in the socket tester where the Dyson had been, 2 green lights so appeared to be wired correctly - flipped the MCB to off on the lighting circuit and the socket stops working.
Take the face plate off the socket, 1 pair of 2.5mm grey T&E so more recent than the house. Trace the wire through the wall up some conduit where it disappears into the loft presumably extended and terminating into the lighting socket. (need to check this tonight)
It appears the previous owner wanted power on the other side of the room for a TV, and the nearest electric without destroying the chipboard floor was the loft and hence the lighting circuit. Could this have caused overheating on the light fittings when a TV/HIFI/Dyson were plugged into the lighting circuit?
Guess I've got some work to do - moral of story - never assume anything.
